Hi there,
So i go to synchronization settings and check the 'detect moved files' option and then i click OK to exit. Then i reopen the synchronization settings and the 'detect moved files' option is back to being unchecked.
The functionality seems to be intermittent. Sometimes it remains checked while at other times it gets unchecked and i have to repeatedly re check 'detect moved files' to get it to work.
Note i am using it for the same folder.
Does this happen with anyone else?
Detect moved files keeps getting unchecked
