[Feature-Request] Exclude-Once
Sorontik
thanks for this great piece of Software, spared me some nights of forcing me a custom crappy script into existence.
It would be very convenient for me, if FFS provided a possibility to ignore one (or more) Folder Pairs for one single Scan/Compare (and thus implicitly the sync as well), without the need to delete them completely, loosing all settings.
I am aware that i can exclude the Folder between Scan and Sync, but for that it has to be scanned first, which can lead to problems like being blocked by another Sync, temporary accessibility problems or simply cost time unneccessarily if I don't intend to sync the Folder anyway. (But i want to keep it saved for later Syncs)
greetings from a thankful user
Soro
markusoft
I set FFS to NOT Save when prompted and basically remove them manually like you and switch back to it, loads it right back up / doesn't prompt to save and screw me up
