Logfile(s)
joombler
Can you tell me where I can find the logfile(s) of my last backup activity?
Thanks, jmblr
jmsxl
On Windows:
%APPDATA%\FreeFileSync\Logs
E.g.: C:\Users\<<user>>\AppData\Roaming\FreeFileSync\Logs
On MacOS:
~/Library/Application Support/FreeFileSync/Logs
Don't know about Linux.
Linux: ~/.config/FreeFileSync/Logs
BTW: The path is also shown under FreeFileSync menu -> Tools: Options.
joombler
Thanks for your help!
Using the registered version, I came out on Windows at %APPDATA%\FreeFileSync\LastSyncs.log
