I get the following error below after updating to 10.8 If I revert back to 10.6 I also get the same error.
There was time under 10.6 when I could sysnchonise root folders on my phone. Can anone point me in the direction of a solution? Just that this used to work! It's very frustrating.
Cannot find the following folders:
ftp://192.168.1.xx
Cannot read file attributes of "ftp://192.168.1.xx".
CURLE_QUOTE_ERROR: QUOT command failed with 502
502 Command not implemented. [curl_easy_perform]
Error: Cannot read file attributes of "ftp://192.168.1.xx".
I'm using ES File explorer to access the root storage.
I'm having intermittent issues with some copying directories using cut and paste, so perhaps not a FFS issue.
Can you test with the following version? Seems like your FTP server does not support the "HELP" command: https://www.mediafire.com/file/4ii9xxfcq3lqs4u/FreeFileSync_10.9_%5BBeta%5D_Windows_Setup.exe
Many thanks for the quick response. It worked perfectly.
For info, this is being used with 'ES File explorer' as a means of backing up files in the Android root memory area using the "Show on PC" feature that then seems to emulate a FTP server. The phone is obviously rooted.
All is well.
All is well.
