Problems to access NAS
justen222
I hope someone can help me out with my problem.
So I use Windows 7 Pro x64 and use the program mainly to sync my HDD data to my NAS. Thats not a problem at all except when I want to do it automatically.
So my PC boots and like 15 mins later it starts a batch file, which runs the FreeFileSynch batch. So the program opens and tries to sync the defined folders.
But then I get the message that it can't find my network shares, even tho they are mounted and accessible in windows explorer. First I thought Windows mounts them too fast, so I tested it with a bat which mounts them 20 seconds after login in but that didn't help either. The connection between the NAS and PC is wired (there are just 2 switches between that) so the network shouldnt be a problem.
Any idea how I can fix this?
Best regards
Just
I've added a new FAQ item with solutions to common network problems in combination with Windows Task Scheduler:
https://freefilesync.org/faq.php#task-scheduler-network
