Error 58 (ERROR_BAD_NET_RESP) - [GetFileInformationByHandle]
I am using a configuration with PC and WDmyCloud2Ex
and FFS10.8 for Windows10
If I want to compare a directory from PC with a directory from WDmyCloud2ex
I am getting this error-message:
Die Dateiattribute von "\\Wdmycloudex2\pc2013\pdfDruck" koennen nicht gelesen werden.
Fehlercode 58: Der angegebene Server kann den angeforderten Vorgang nicht ausfuehren. [GetFileInformationByHandle]
Cannot read file Attributes from WDmyCloud2ex
Error-Code 58: [GetFileInformationByHandle]
What I have to do to compare with FFS, maybe changing Attributes??
Are you sure, you're not still using FFS 10.7?
FFS 10.8
Build 15.01.2019 - Unicode x64
Can you send me a Process Monitor trace, starting when you hit retry and until after the error message comes up? https://freefilesync.org/faq.php#trace
Hey Zenju
I hope this is the right file for Monitoring - Locfile.PML ??
But I don't know how to send it to you - 189MB??
Just upload it somewhere and send the link. Or just compress it.
I send it via WeTransfer.com
You should get an email-link from WeTransfer/dag01
Thanks! Can you test with the following version and post the error message (if you get any):
https://www.mediafire.com/file/509xwzc8pflqlpz/FreeFileSync_10.9_%5BBeta%5D_Windows_Setup.exe
with FFS 10.9beta COMPARE works without any Problem,
but Mirror-Transfer from PC to WDmyCloudEx2 sends this message:
Die Dateiattribute von "\\Wdmycloudex2\pc2013\pdfDruck\442_WEA_Infoquellen_Ertrag_PN20190112a.ee41.ffs_tmp" koennen nicht gelesen werden.
Cannot read file-Attributes from WDmyCloudEx2...
Errorcode 58
This is send - I suppose - for every file!
Errorcode 58
It seems the "GetFileInformationByHandle" function is generally not implemented (properly?) by the server. If there is not any newer firmware available for the device, this is worth a bug report on the "WDmyCloudEx2" support website.
I talked with WD-Support.
A new Firmware was installed but with the same results/Errors.
WD has controlled the system-protocol - everything seems to be ok.
Maybe they will implement this problem in a Firmware-update,
but they say that this is no WD-Problem - so maybe…
You see another way for Clearing this Problem?
Only my configuration makes this Problem
or maybe other users have the same Problem with FFS and WD?
PS: Maybe you want to see the WD system-protocol (zip-File)?
How did they come to this conclusion?but they say that this is no WD-Problem dag01, 04 Feb 2019, 11:52
The WD-answer/email is in German, but maybe you'll be able to translate it.
They say, it is no WD-Problem because after control oft my WD-protocol
they saw, that everythings on WDmyCloudEx2 is working as expected.
I also send the zip-file with the WD-protocol, maybe it´s interesting for You!?
GetFileInformationByHandle isn't exactly an exotic API, but a pretty basic building block for (efficient) file copying. I don't quite understand why they haven't implemented it (if that is what is causing the error).Unfortunately third-party software is not supported by WD.
Nevertheless, we have forwarded your feedback to the appropriate team. However, we can not guarantee that changes to the My Cloud firmware will be made to work with the FreeFile Sync software. WD level 1 support rep
Of course FFS could implement a (slow) workaround without "GetFileInformationByHandle", but it seems only WD has this problem and the API is needed in quite a number of places.
I'd like to give this another shot. FFS might use an alternative API as a fallback to handle cases like the server not supporting a specific command. I suspect the server only has issues when GetFileInformationByHandle is called on a folder, so let's see if the following version works:
https://www.mediafire.com/file/j7r9v1p7v5k33yq/FreeFileSync_10.10_%5BBeta%5D_Windows_Setup.exe
Hey Zenju
thanks for supporting with the new FFS-Version.
but ist the same effect. Comparing is ok, but copy to WDmyCloudEx2 receives ErrorCode58
Fehlercode 58: Der angegebene Server kann den angeforderten Vorgang nicht ausführen. [GetFileInformationByHandle]
Maybe there's something wrong with the beta, it shouldn't be possible for you to get a "GetFileInformationByHandle", error because I'm not using it during comparison. I've restructured a few things, please test with the following beta version instead:
https://www.mediafire.com/file/e7m1evgeldnkbgu/FreeFileSync_10.10_%5BBeta%5D_Windows_Setup.exe
Hey Zenju
it's also the same effect with Beta 05.03.2019
Comparing without any Problem, but copying to WD receives the ErorCode58
Can you post the full error message? As always I'm interested in the little details.
So that's an improvement, as comparison was not possible before! And I haven't checked on the sync part yet.Comparing without any Problem, but copying to WD receives the ErorCode58 dag01, 05 Mar 2019, 19:16
Seems, we've been there before: viewtopic.php?f=8&t=6016&p=20255#p19806
This new version should fix the sync part as well:
https://www.mediafire.com/file/5qpc1msc006d4oh/FreeFileSync_10.10_%5BBeta%5D_Windows_Setup.exe
The "price" for this workaround is that move detection may be (partially) not working, in which case FFS falls back to copy + delete.
This new Version also with the same results (just like in V 04.03.2019 !!)
o comparison ok
o copying/Writing to WD receives ErrorCode58
Cannot read file attributes of "\\Wdmycloudex2\pc2013\pdfDruck\400_VDE_5-Fakten_Voltimum_20190122a.3e48.ffs_tmp".
Error Code 58: Der angegebene Server kann den angeforderten Vorgang nicht ausführen. [GetFileInformationByHandle]
o comparison ok
Alright, the following version will definitively give a different error message (or maybe even work, who knows): https://www.mediafire.com/file/v9zy48bno7o8smd/FreeFileSync_10.10_%5BBeta%5D_Windows_Setup.exe/file
PS: in case it "works" it would be interesting to know if new folder creation on the network share also works.
Hey ZENJU
IT WORKS:-)
it also creates subfolders and copies files into the new created subfolder!!
MANY THANKS :-)))
PS: The Version is FFS 10.10 Build 05.03.2019 [Beta]
Maybe in future it would be better to add an index (like "_a" or "_b") because now there are several versions of 05.03.2019!
Last installed version is from "FreeFileSync_10.10_[Beta]_Windows_Setup(11).exe"
IT WORKS:-)
MANY THANKS :-)))
Awesome! I still consider not supporting GetFileInformationByHandle a major bug on WD's side, but at least it's not FFS's problem anymore.
Installed v10.10 beta
Accessed WD NAS drive successfully.
COMPARE ran successfully.
New file created on target WD NAS drive successfully.
10.10 fix looks good.
Hate to bring this up but I'm having nearly the same issue, but on a RAM disk. I've been following this thread for a week or so and the 10.10 beta posted March 6th hasn't helped. E:\Firestorm\FSCache is mapped to my RAM disk. This is what I'm getting:
Cannot read file attributes of "E:\Firestorm\FSCache".
Error Code 144: The directory is not a subdirectory of the root directory. [GetVolumeInformation]
I also get a similar message when pointing it directly to the RAM disk, Q:\.
Cannot read file attributes of "Q:\".
Error Code 87: The parameter is incorrect. [GetVolumePathName]
OS: Win 10 Pro 10.0.17134
Processor: i7-2600K
RAM: 32 GB
I tried to post screenshots of the error dialog but was chastised and accused of being a spammer lol.
Processor: i7-2600K
RAM: 32 GB
What kind of RAM disk is this?but on a RAM disk. Mace68, 09 Mar 2019, 05:31
Yeah, I guess you can tell I'm sick and tired of forum spam.I tried to post screenshots of the error dialog but was chastised and accused of being a spammer lol. Mace68, 09 Mar 2019, 05:31
It's a software configured ramdisk by ASUS.
https://rog.asus.com/technology/republic-of-gamers-motherboard-innovations/ramdisk/
Darn, I had hoped to be able to reproduce on my end, but I don't have an ASUS board. Anyway, the above issue should be fixed with the following beta. I'll be releasing the next FFS version tomorrow, so it would be great to get this issue finally resolved: https://www.mediafire.com/file/48852l3zfdh722w/FreeFileSync_10.10_%5BBeta%5D_Windows_Setup.exe
You can get it on the Drivers and Utilities download section of the ROG Maximus XI Extreme support page, and thank you.
So it seems to need an ASUS board to run.The RAMDisk software is exclusively offered on selected ASUS ROG product lines.
