I know that this topic was discussed a couple of years ago, but for Android. Could not find anything specific to Mac and would appreciate some advise.
I sync my MBP running on HighSierra 10.13.6 with a QNAP server TS269, using FreeFileSync 10.8 Donation Edition. The error message comes now on every folder I have a new file in. Tested it with Word, Excel and Pdf, and it happened in the first attempt when there was no copy on the server yet. It creates there a ffs_tmp version and delivers the error message. When I try to sync again, it tries to delete the ffs_tmp version on the server, but w/o success.
When I then copy the files per finder an then run the sync, no error message shows anymore.
Any help appreciated. Thanks
unexpected size of data stream Mac HighSierra
Using FTP? viewtopic.php?t=6009
Zenju,
Thanks for the link. However, the linked beta version 10.9 is for Windows while I am working on a Mac. Any beta version for HighSierra?
Further, have now deleted the server version of one of my sync jobs and copied the entire folder again. Now the following message comes: CFStringCreateWithBytesNoCopy: allocation failed.
Do you suggest I go back to 10.7?
