Donation not detected?
Hello, I just made a donation. How can I download the portable version?
Just extract the contents of the zip file you downloaded into a single folder (this will give you two files in the folder). Then launch the FFS installer. During the install routine select to 'install' as a portable. You don't need to download a separate 'portable version'. There is an illustration of this in the FFS FAQs - Portable Installation
(Above said, I've never used the portable myself, just notice the option when I do a full install.)
