Take files from Several folders and sync to One folder
Thermidor2
The camera utility on my device stores photos in "date" subfolders, one for each different day. I want to sync the photos to a single destinatrion folder. So for example, the "sources" might be:
c:\camera\pictures\2019_02_10\
c:\camera\pictures\2019_02_11\
c:\camera\pictures\2019_02_12\
c:\camera\pictures\2019_02_13\
etc, etc . . . .
I want to sync all the photos that are under "c:\camera\pictures\" and all it's sub-folders to the root of folder "d:\pictures\" - with no date subfolders.
I have used a filter of "*.jpg" in FileSync - which makes it appear like it's going to copy only the files, but when I run it, it copies the files within their "date" folders.
Is there an easy way to get what I want?
Cheers.
Try running a compare and then use the ctrl-T option.
See the corresponding Manual topic.
