Hi, just found your program (FreeFileSync).
Very nice application, just what I needed now I have a phone that only has "Media Transfer Protocol" :(
Tried to use RealTimeSync, it says MTP dose not support directory monitoring.
Are you working on a workaround so that RealTimeSync can work with MTP devices?
Tim
Real Time Sync [MTP]
RealTimeSync relies on directory monitoring.
And as indicated, MTP (just like FTP and SFTP) does not support that.
Zenju (the author) is performing miracles, but don't expect him to do the impossible ...
I just thought:
As FreeFileSync is able to sync an MTP device, perhaps RealTimeSync could be made to detect USB device connection, if it detects a USB, it then checks to see if there is the MTP path specified.
Just a thought.
It would be nice if it could do that.
Tim
Just a thought.
Tim
