I recently went to do a mirror transfer from an internal hard drive to an external hard drive and put a bunch of filters on but then decided to clear them all and pick different filters. When I did this and went to compare the drives I started to get Error code 5:Access Is Denied. I think I fixed the issue by running FFS as an admin and enabling the system volume and recyclebin filters? Are those the default ones? After I did that the sync worked but I think I was still in admin mode so I don't know if I fixed it in regular user mode.
Also I think when that happened it turned a bunch of stuff into read only. When I uncheck the read only boxes and close out of the file properties they recheck themselves. Any ideas what to do here?
Thanks.
What are the default filter settings?
