When I'm starting my sync job I'm having 3 active diplays. While the comparaison is going on, I'm preping myself to get out of work by unplugging added display and all oppened windows goes straight to the remaining windows but while the comparaison operation is completed, the confirmation screen to press "GO" is never displayed and the main screen of the program is innacessible.
When this appen, I muste Terminate the process and start again as the software waits for a "GO" or "CANCEL" but I don't have any windows to click it.
Disable multiple display cause confirmation screen to vanish
This was a bug in wxWidgets.The dialog is positioned off-screen, so you could get out by pressing "ESC". Anyway this bug has been fixed: https://www.mediafire.com/file/633bz7ebqcz592c/FreeFileSync_10.10_%5BBeta%5D_Windows_Setup.exe
Thank you very much !This was a bug in wxWidgets.The dialog is positioned off-screen, so you could get out by pressing "ESC". Anyway this bug has been fixed: https://www.mediafire.com/file/633bz7ebqcz592c/FreeFileSync_10.10_%5BBeta%5D_Windows_Setup.exe Zenju, 05 Mar 2019, 18:03
