SSH tunnel
Does anyone know if it is possible to use FFS via one or more SSH tunnels?
WinSCP enables this by adding an extra login for the tunnel host.
FFS runs just fine via an (IPsec) VPN tunnel. Did not try other tunnels.
However, you have to open the tunnel yourself up front (before launching the FFS Compare and Sync).
