I use FFS to synchronise folders between two desktop hard disks.
The comparison stage takes quite a time and if the connection fails and I have to login again into the Remote PC, this comparison stage fails.
In essence it can no longer find files in \\tsclient\D\........ and I am given the option of retry, which of course doesn't work and cycles through the files.
If I open a second FFS app, this can find the drive.
Using Remote Desktop \\tsclient\D\ can't be found after a short disconnect
Doesn't anyone else use Remote Desktop to sync files with a remote PC?
