Hello ..... I have been to a clients today that has a new PC loaded with Windows 10 pro v1809. It is fully up to date update wise.
Installed FFS (latest version from the web site) and setup the folder pairs. Saved the settings and saved also as a batch file. The first thing I noticed was that the batch file icon was not the usual black and green but the standard FFS icon. Bit odd - never seen that before.
When I went to run the batch file it fails with a message regarding various XML config issues.
I have never had an issue before - ever.
Anyone any ideas?
Cheers
Mick
Batch file fails to run
I have tried v10.10 and 10.4 but still have the same error.
When creating a batch file the icon for this is the same as the standard FFS config icon-the double arrow and not the single arrow on black for the Batch file.
Then when running the saved Batch file I get the error below
This is a clean W10Pro install. Any suggestions on this would be great. Thankyou
Can anyone help on this please?
Is there any support on this at all?
