Suggestion: easier scheduling
Bob4K
FreeFileSync is an incredible tool, I want first to thank everybody who made it.
There is just one thing that I think could be easier to do: scheduling.
Currently, correct me if I am wrong, you have to create a batch file and use the Windows scheduler.
Ideally, one should be able to right click on a backup for example, select a "Scheduling" menu item (currently there is only a delete entry), and see appear a popup window with all the scheduling options.
Just my 2c to make an incredible tool a little bit better.
ehc
I fully agree. The scheduling would bring great improvement to the tool, which alias is the best.
