RealTimeSync does not monitor folders in the cloud
Hello, the RealTimeSync software part tells me that it does not support the supervision of directories when I indicate a folder that I have in the cloud, so I understand that it is a function that the program does not include, it only monitors changes in the local folders for the synchronization, but I have several teams that make changes in the folders of the cloud and I would like at that time to synchronize, I would like some software update to include that support if possible (I would be willing to pay or donate more) since I have to combine the software with others that mount the unit of the cloud as local as for example RaiDrive or Mountain Duck, although this system does not work very well since it produces me excessive consumption of ram or excessive slowness. a greeting
This is not a limitation of the FFS program, it is a limitation of several cloud systems.… so I understand that it is a function that the program does not include, ...
Those cloud systems do not support monitoring the cloud location for changes.
FFS can not use what the cloud system does not support.
Instead of using RTS to monitor for changes, you can try running FFS at regular time intervals as a scheduled task.
Thank you very much for the clarification
