Copy one source folder/drive in multiple folders/drives
Hellwarrior
sorry, I'm new in using Freefilesync und I haven't found a solution for my question.
I have one source folder on my laptop which is always up to date.
I will synchronize this source folder on two harddisks in parallel (one harddisk for backup, the other as a transfer drive).
How can I setup this scenario with Freefilesync?
Thank you!
Define multiple (2) left-right base folder locations. See here.
For both left-right pairs define your laptop base folder as the left-side location.
For the first left-right pair define your backup HD as the right-side base folder.
For the second left-right pair define your transfer drive as the right-side base location.
Hellwarrior
It can be so simple. :-)
Thank you for you help!
