When i use FFS on my PC, everything works fine. But if i sync my smartphone, there are errors like:
Die Datei "****.8fc7.ffs_tmp" kann nicht geschrieben werden.
Unerwartete Größe des Datenstroms.
Erwartet: 19953853 bytes
Tatsächlich: 18669568 bytes
(can't write file, unexpected size of data stream)
What does that mean? It happens with mp4 files only. Most of them work, some won't.
Problems with mp4 files on smartphone
Sounds like this Android bug: viewtopic.php?t=578
