Hi folks,
I'm a newbie who has just migrated from Win 10 to Mint 19. On Windows I used SyncBackSE for backups and will be using FreeFileSync on Mint.
I've had a read of external-applications and topics p11941, p10555, p20842, etc. but they don't seem cover what I'd like to do. (I realise I can write a script to set %Right_Target_Path% and run it using a command line but I was hoping for something easier/simpler.)
The setup I had on Windows, and which I'd like to replicate with FFS, was as follows:
- each source (e.g. C:\live_files\*.*) had a primary and a secondary mirror and was copied on a schedule to separate SSDs (F: and G:)
- non-volatile data (e.g. archives, music) was backed up to a non-time-differentiated directory structure - e.g. F:\music_backups\
- volatile data was backed up to daily, weekly, monthly and annual backup directory structures - e.g. F:\daily_backups\Mon\, F:\weekly_backups\Week_1\, F:\monthly_backups\Jan\, F:\annual_backups\2019\, etc.
Given the age of the earlier posts I suspect that this isn't something that's in the pipeline at present.
All help will be most welcome.
(There's a full list of SyncBackSE variables, etc. on the 2brightsparks website.)
Regards,
John
variables in filenames
Did you check out the use of Macros ?
Thanks Plerry,
As I said, I'm a newbie.
I can use %year%, 'month_%month%' (instead of 'Jan', etc.), and %weekday% (instead of 'Sun', etc.).
I can also use 'week_%week%' but, as there's no %WEEKOFTHEMONTH% equivalent, I'll need to manipulate it so as to cycle every few weeks, or keep only the last few weekly backups.
Regards,
John
Regards,
John
Try resubmitting this as a [Feature Request] in the "General discussion" section giving also this link as a reference:
Variables defined/managed by SyncBack
But probably you can create the few variables you need in a .bat script that than launches FFS.
Hi Gianni,
Given that there's been no great clamour for such things I just wrote a script instead.
I'm happy to provide a copy to anyone who wants one.
Regards,
John
Regards,
John
Hi John,
I'm interested, thanks!
Hi Gianni,
ISO 8601 doesn't specify what "week_of_the_month" is so I chose to define mine as being relative to the week_number of the week containing the first day of the month. Subtracting 1 from the week_number of the first day of the month gives an offset. Subtracting the offset from the week_number of any day in the same month gives my "week_of_the_month".
I'm attaching a .txt copy of the script which I use to run FFS batch jobs.
It also does some pre- and post-FFS housekeeping.
I had a few problems getting it to work via cron - details in the 'running batch jobs via Linux cron' thread.
It looks prettier in xed, without the .txt, but I couldn't attach it without an extension.
Let me know if you want any more info.
Regards,
John
Regards,
John
