Auto Update feature, requirements
chuckv
What is required for the (every 1 week) auto-update feature to kick-off?
For instance, I'll be calling FFS from the task scheduler on login, running a batch profile... but never running FFS manually. Will it still update every week if the feature is checked?
Thank you,
Chuck
The auto updater (or even only the update check) is not run in batch mode (ffs_batch).
chuckv
Thank you for your reply.
Any suggestion on how to get FFS to auto-update (automatically) when it runs a batch from task scheduler on login?
Thank you,
Chuck
Zoltrix
Also wondering the same. I want to upgrade to the donation edition, but would need it to update without user intervention...
