Hi there!
I just encountered this error, which is frankly the first issue I ever have with your excellent, excellent software :-)
The only further details I can provide is that it states "CreateFile" is using the xml config file. I tried deleting GlobalSettings.xml and letting FFS create a new one, only to get the same error the next time I run it. However, I must say it doesn't even happen every time - if I try and open FFS quickly after closing the error window, it runs just fine, but it persists on subsequent runs.
I updated to 7.8 (portable version) a few days ago, and it's worked fine for a few days until right now. I'm on Windows 7 64 bit.
Cheers!
EDIT: viewtopic.php?t=1716
Error code 32: Cannot open file "GlobalSettings.xml"
