USb Drive Is Not Readable and it's lock Read Only
Vas
Please Help me.
I have USB 128 GB Ntfs Flash Drive and Windows 10. When I was Syncing File With FreeFileSync & Power went out So when Came Back I restarted Computer, Now USB drive is "Read Only" and can not Delete Partition or Format or nothing that i can do, i have tried the Testdisk, Computer Management, Diskpart, AOMEI Partition Assistant Standard Edition 8.2 and EaseUS Partition Master 13.5 but can not do anything i Have Donation Copy of FreeFileSync. Now what Should I Do?
Sounded like a corrupt flash drive, but if you can't even format it anymore, it may have corrupted the flash controller. I would be doubtful though. If diskpart can't run a clean command on it, then it is done for
