is it possible to change this? It is not possible to get it working at work where we have corporate SSL certificates. How am I adding?
CURLE_PEER_FAILED_VERIFICATION: SSL certificate problem: unable to get local issuer certificate [curl_easy_perform]
Google Drive: CURLE_PEER_FAILED_VERIFICATION
FreeFileSync (starting with version 10.11) added the cacert.pem file from https://curl.haxx.se/docs/caextract.html.
You can append your root certificates to the cacert.pem used by FreeFileSync. I've got a blog post about all sorts of random certificate commands, which includes "Convert cer to pem format" which is useful if your root certs are Active Directory certs: https://bgstack15.wordpress.com/2016/06/30/manipulating-ssl-certificates/
Is this for FTP or Google Drive?
Google Drive problem in Company network
And I have Portable version
The error is originating from OpenSSL, where it has the symbolic name:
Maybe it indicates an issue with accessing the "cacert.pem" that is shipped with FreeFileSync?X509_V_ERR_UNABLE_TO_GET_ISSUER_CERT_LOCALLY : unable to get local issuer certificate the issuer certificate of a locally looked up certificate could not be found. This normally means the list of trusted certificates is not complete.
Do I have a portable version, should I try to install it normally? I don't know where to find the cacert.pem file
And would it be possible to download an older version somewhere? Lower than 10.11? To try it?
See the FFS Archivewould it be possible to download an older version somewhere? kalich, 01 Jul 2019, 08:17
In version 10.8 the program writes to me: www.googleapis.com not found and problem with SSL certificate
DONE, work :-)
How did you get it to work?
There was a problem with the corporate firewall
