Hello everybody,
is it possible to ignore folders via control files instead of the file/folder pattern?
Thinking along the lines of git or svn. Create a .ignore file and the folder is not synced...
Thanks for your help
Greetings
Peter
Exclude folders by files
You can right click a folder in the sync window and exclude it in the saved program
