Hi everyone. I have two folders which have different folder structures within them - is there a way to run a "compare" to see whether files on the left exist on the right regardless of which folder they are in?
For example, if there is a file: Folder/document/projectx/sony.doc on the left side and the same file exists in the right in Folder/Sony/sony.doc, then it should not show up in the compare. I am only interested in making sure files that don't exist on the right side show up so that they can be then synced over.
Any help will be very much appreciated. Thanks!
Feature for knowing file existence regardless of path?
No, that is no longer syncing and requires a different method of comparing.
