Is there a way to check if files on the left are anywhere on the right? For example:
Left Right
c:\folder 1\FileA d:\folder 2\folder 3\FileA
FileA on the left is in a different folder compared to the same file FileA on the right. But it is the same file.
If this is the case I would like to choose to skip the copying of FileA.
Now it seems that I can check if FileA is present or absent in the matching folder on the right.
Can you please help me? Thanks in advance.
Kindest regards,
Rob
Files to the left anywhere on the right?
Already asked and answered: see here
