feature request: option to rename file when an illegal character is found
scramasax
I was syncing folders from my ubuntu computer to my qnap nas with smb protocol and I got a lot of errors about illegal character in file and folders. It is not clear From the popup error if renaming the file outside the software and pushing retry would catch the renamed file or not. A button to rename the file or folder would help when some error are encountered like
Code Erreur 2: Aucun fichier ou dossier de ce type [mkdir]
Code Erreur 22: Argument invalide [open]
I encountered question mark, colon and pipe symbol in filename and colon in folder
On following use since everything has been renamed there should be less of them
It would not. It will only sync the previously detected modifications. You would have to rename and then compare/sync again.
