Program changes file values of all compared files on MS SharePoint
jesko13
Very good program: fast, reliable, easy to use.
But now I am facing a problem, I can not use freeFileSync anymore.
Version: 6.0
Problem: Even if I only compare a local folder with a SharePoint folder and all files are the same, freeFileSync changes the "Modified By" and the "Modified" (date) value of 90% of the SharePoint files.
I can't explain why not for 100% of SharePoint-files. It also does not perform changes for folders.
Nevertheless, if you work in a team with MS SharePoint, it is not usable. Everyone is confused in thinks I have changed anything on the files.
Any idea?
