I would like to compare and sync in one step without an extra mouse click. It should be done in administrator mode and thereafter the computer should go into standby mode. How to do that?
The ffs bat files do not start the program in adminstrator mode. If the property settings of ffs enable the admin mode, a click onto the ffs bat file lead to an error message,
Syncing in one step
You can create a shortcut on FreeFileSync.exe, set it up to run with admin rights, and give a ffs_batch file as argument.
