Installer hangs
exyll
Since a few releases the installer hangs. I'm not sure exactly why.
Unfortunately, the forum doesn't allow to post screenshots as I'm not allowed to link to a image because I'm new.
The image url with a space in the schema
Which operating system are you using?
exyll
I'm running Win 10 build 1903 build 18362.239
exyll
It seems a powershell session is created which hangs as when I kill that the installer continuous.
This is related to viewtopic.php?t=6312#p20750
In any case the FFS installer will call powershell asynchronously from now on, so at least it won't hang anymore:
https://www.mediafire.com/file/ueop17ug0jnfasi/FreeFileSync_10.15_%5BBeta%5D_Windows_Setup.exe
exyll
ok, not sure what relation with google drive is. As said, after stopping/killing the powershell process the installer completes and FFS seems to run just fine.
