Error Code 2
Tried to post screenshots of the error, but was denied.
Trying again.
Here's what I run:
And here's the error:
The file path "C:\Program" seem very strange, but it's not entered by me.
What am I doing wrong here?
Here's what I run:
As you can read in the Manual page on RTS, RTS requires a command line that calls FFS and specifies the *.ffs_batch file as an argument .
Your command line only provides the argument, not the FFS executable.
RealTimeSync is using shell execute on Windows, so the above example with just specifying the .ffs_batch file path should in fact work, provided the OP is using the local FFS installation so that file associations are set. In any case, I have no idea how the two screen shots could be connected, and I'm certainly not able to reproduce this sequence.
File: "C:\Program"
Arg: "Files\FreeFileSync................."
How does this happen?
It seems to me that FFS does not read its own path correctly, since it does not "approve" the space in the pathname at "Program Files".
