BatchJob that will copy only the old files
sinefile1
Good Day!
Hope someone can help about my problem. I have NVR folder that want to copy all saved files to another location but only the old files, not the updated one.
If I can created and BatchJob using FFS and put it in task schedule, then it will be all automatic.
Or is this possible for FFS?
Thanks in advance
You can try the FFS time-span function.
If you set the From date very early, and the To date according to your need, this can likely do the job.
