Can FFS be set to run with no manual intervention?
ie... When Keepass opens my data file, Can FFS detect that a file open is requested and go out and see if a new sync session is needed because the server-located file is newer than my local file...(And thus trigger a fresh sync (Binary files, BTW)?
And, when I close Keepass, can FFS detect a file change and do the sync?
oh... on a MAC... Running OSX 10.13 (High Sierra) and another Mac running Mojave
Can FFS run always and detect File Changes
You can use RealTimeSync (RTS) for monitoring changes,
and use RTS to launch FreeFileSync (FFS) to perform the actual sync.
