Nothing to Synchronizing
terick
Hello everyone
I have right click on the FFS and ran as administrator and it works, but when trying to create a new batch and run the synchronize button, and completed successfully, but when checking a batch folder of the synchronizing and nothing have synchronized. I go to check the log and says that Nothing to Synchronizing.
Can anyone help this is issue please?
Thank you in advance
kolos123
Did you create the file after you entered the folder path in the FFS UI?
If so, you need to refresh the file list by reselecting the path or just pressing enter on the path textbox.
Can you provide some screenshots of your settings, source/destination, and compare window?
