I wondered if I could set up RealTimeSync on Windows to run as a user which has the credentials for the destination network location saved in their credential manager without that user needing to log on, and have it sync files created on the local drive by other users that do log on interactively. That way the interactive user wouldn't need access to the network location set as the destination.
I created a scheduled task to start RealTimeSync at startup and I can see from task manager that it is running under the correct user context and when a change is made to the source folder a new log file is created but it always says Nothing to synchronize.
Should it be possible to operate RealTimeSync this way and if so, any ideas what's going wrong?
RealTimeSync running as non-interactive user but not syncing
Oops. I thought the batch job had the correct comparision and synchronisation settings but I could see when I checked in the FreeFileSync GUI that they weren't. It's working nicely now that I've corrected them.
