Mac: permission to copy photolibrary
GiLib51
Hello everyone. I need help solving an annoying bug
The specifics of the problem are as follows.
FreeFileSync 10.15 for Mac
Version 15.08.2019 - Unicode x64
OS X version: Mojave 10.14.6
Error when I attempt to copy the Photolibrary to the HD backup:
Impossibile aprire la cartella “/Users/luisa/Pictures/Foto di Luisa.photoslibrary”
Codice errore 1: Operation not permitted [opendir]
It is necessary to allow FreeFileSync to access Photo. How can the problem be solved?
Thanks for a prompt reply
Does the error go away if you grant FreeFileSync "Full Disk Access"?
http://osxdaily.com/2018/10/09/fix-operation-not-permitted-terminal-error-macos/
GiLib51
Hi, Zenju.
Many thanks for your reply and your suggest.
I try immediately and then I'll report you.
GiLib51
Hi, Zenjus.
Problem solved!
Once again, many thanks for your support.
Have a nice day
