Not functioning
grimley
Nice looking program, but it doesn't work. After SFTP login, no directories appear. "Browse" brings up local directories only (in both windows). Good luck.
grimley
Windows 10
Neither pane will display directory / files
SFTP connection is not acknowledged (although chosen remote directory appears via connection window)
"Browse" brings up directories on local drive (in both panes) after SFTP connection has been made
The "=" selector at bottom of program window will bring up files (correctly) in both panes
...otherwise, blank on both sides
I don't understand what kind of problem you're seeing. Do you have some details, or screenshots?
