Time Difference not ignored
hgrdrro
Hi, at first let's state, that FreeFileSync is a very, very good software and I like working with it.
I am trying to synchronize a PC located in the US (EST) with a cloud-based Server PC in Germany.
The time difference is six hours. Even if I have set up the time difference to 06:30 FreeFIleSync shows to me all the files as different, even if they are not.
Do you have any idea what I have made wrong?
I very appreciate your oncoming development and your response.
Because I am so happy with your software I donated one portable version, but without thinking about, that this is not really fair, I installed it on six computers. Is there an easy way to "unlock" five of these installations?
Best Regards
Hans
https://freefilesync.org/manual.php?topic=daylight-saving-time
File times have to be equal or differ by exactly the time shift entered to be considered the same. Therefore, the time shift setting should not be confused with a time interval or tolerance.
