Synchronization between two locked database files
qwers147
Hi, In windows 10x64 I am trying to synchronize two database files both currently are in use. One of the files is on the another pc in the network. FreeFileSync enables us to read from locked files. However; FreeFileSync cannot write on database file that is currently in use(locked). Is there any way to achieve this? Thank you in advance.
No. You can't change a file that is currently in use by a process.
