You must be logged in as an administrator when installing this program.
jasonebianchi
Any work around for "You must be logged in as an administrator when installing this program." when trying to run FreeFileSync_10.16_[Donation_Edition]_Setup? I use this primarily for work and the computer is locked down by the IT department. Thank you.
You can use the portable version which doesn't need installation.
