Freefilesync prompting for password
Freefilesync prompting for network drive password with error incorrect network password when sync local drive to network drive after system reboot. in freefilesync error log shows incorrect network password but when check map drive status its show okay. can someone help me please.
What does "prompting for network drive password with error incorrect network password" mean?
Are you using the drive letter assigned to the network folder?
I had tried using drive letter or without drive letter in both cases same issue faced when system shutdown and then start again.
Error: Unable to connect to "\\192.168.100.17\Anant".
Error Code 86: The specified network password is not correct. [WNetAddConnection2]
this is the error msg comming.......
Did you enter an incorrect network password when using FreeFileSync? Or was the password buffered by windows in one of your earlier network accesses, and it was not correct?
