How to make a plannning of my backup?
I wish to do that automatic.
One step at a time.
Look at this webpage: https://freefilesync.org Watch the Tutorials which are videos that give quick insight as to how to work with FreeFileSync (FFS). Once you've done that read the Manual and the FAQs.
After you've done that experiment with FFS a bit. Then if you have problems post to this forum on how to solve problem 'x'. When you post a request for help explain exactly what it is you want to do.
If you want to setup automatic syncing of files then you will need to use RealTimeSync (RTS) -- details are in the Tutorial Videos and the Manual. That said, you might be better using the FFS GUI first for a while until you have some understanding of how FFS works.
P.S. It's not a good idea on public forums to give as a username your email address (if that is what you have done).
