Notification sounds
battles
I usually don't use the 'Compare' button, but go right to the 'Synchronize' button. I would like to see the Options / 'Notification sounds: Comparison finished:' alarm sound off when the 'Start synchronization now?' box pops up.
There is a setting in options to select a sound to play when compare is done. Although, when I click synchronize only, it compares and automatically runs the sync. Try saving as a batch job.
