I have below problem with my "new" pc.
When I make an analyse and thereafter a copy of my documents, the Outlook file is not included. How can I get this file to be included so that I can make a copy to my back-up disc?
With my old pc the Outlook file was copied.
Kind regards
Finni
Outlook not copied
There are many possible issues. If the file is locked, if it resides in a directory without read permissions, exclusions, etc. Do you get an error message? If you do only a compare, do you see the outlook file get "queued" up?
I don't know it the Outlook file is locked, if it resides without read permission etc..
Is that something that could take place in the FreeFileSync program, or will it be in the Office package?
The Outlook file is NOT shown when I do an compare. (It was shown when I did a compare in my old pc).
Either the paths are incorrect or there is some funky filters going on
