plenty of FFS processes in taskmanager
begesf
Hi, after having started several batch jobs for FFS I found plenty of FFS processes (both 32 and 64 bit) in the task manager, althouh the jobs were finished already. Doesn't terminate FFS it's processes after having accomplished a task?
Windows 7 Professional 64 bit
petrovski80
It does. Unless you've set the batch job option to show the process dialog or set the error handling to popup.
