[Feature request] Ability to set default variant for new configs.
titleunknown
Default variant for synchronize is set to Two Way and I would love it to have the ability to set this as Mirror Would also like to be able to set "detect moved files" as a default selection as well.
These are both items that I must toggle each time I create a new configuration (which is quite frequent) As I almost exclusively use Mirror variant.
As a workaround, copy and paste the job file then rename. Then you don't have to change sync settings
titleunknown
I've had issues with database corruption doing things like that and having files disappear when not sending files to trash.
As far as I have seen, FFS looks for a db file in the directories, so if you change the source/detinstion, it won't have one, then will create a new one
