I have RTS doing a FTP load when a new file is generated but it starts the file transfer before the local file is complete. Is there a delay setting or something I am not doing correctly in the FFS setup?
Thanks!
Transfer starts before file is complete
Apparently the local file that triggers RTS is written in multiple "bursts", with more than the RTS Idle-time in between.
You may try to adjust (increase) the Idle-time setting of RTS to be equal to at least the maximum time between such bursts.
