FFS and raspberry via sftp
gona
i cannot reach my raspberry pi 3 through freefilesync.
i have remote access to it via termius and I can sync it via mobile (android) with Foldersync, but not with FFS...
This is the string to connect Raspberry in FFS
sftp://pi@X.XXX.XXX.XXX:xx/|timeout=10|pass64=xxxx=
answer is: impossible to find the folder
on Directory on server i tried:
\Home
\Home\pi
whithout success
Any suggests?
Thank you!
The error message is correct, "\Home\pi" doesn't exist (but "\home\pi" does).
gona
Thank you
I tried, unfortunately it doesn't work.
What can be?
Just use the SFTP folder picker and see what's there.
