gpx-files will not be synchronizised
MaxBubu
my gpx-files (Tracks, Waypoints etc) will not be synchronisised;
When I click "compare", these files are not listed in the source directory; all other files in the same directory (docx, jpg ..) are!
In the Synchronisation Settings/Inculde I have written \*.gpx ; doesn't help!
Any idea? What's my mistake?
Peter
Sorry for bad english - I'm german ;-)
You should include "*.gpx" or just "*"
MaxBubu
THX for you answer!
I tried this - of course - before I postet my problem here!
The "*" is - as you know - defaut, and other syntaxes like "*.gpx" didn't help anyway.
I tried it on several systems, so there should not be a fault in the SW in the systems, which I want to synchroise. The failure happens in both directions.
